Group: DynoMotion Message: 6552 From: chrismd500 Date: 1/23/2013
Subject: Camera lens control with miniature stepper motors
I'm using the kflop/kstep for an structured light 3D scanner with machine vision / CCTV cameras. These cameras doesn't have a lens controller in them, so everything is manual when it comes to the lens. It's a pain to re-focus the lens to the object as the cameras/scanner is relatively far from the computer screen.
So instead of buying a $3,000 lens controller and new lens i was playing with the thought of putting a small stepper motor with a pulley and a flat belt or o-ring around the focus adjustment ring on the lens. The idea is to tension the belt in such a way that it easily slips when the focus reaches max min. The lens focus ring is 50mm in diameter.
I have a couple of questions regarding miniature stepper motors:
1) What is the smallest motor I can safely use? I know that kstep has a minimum current of 0.63A on each channel, are there ways to put a motor with a lower maximum rated current than 0.63A to kstep (without having the risk of destroying the motor)? There are some NEMA 8 motors rated at 0.30A and 0.60A available, but would have liked to use a motor with a smaller footprint.
2)I know that Tom and others do not recommend having two stepper motors connected to the same channel. I just wonder what problems it will cause (especially if using two identical "miniature" stepper motors connected to one channel)?
3) Does anyone know where I could get some smaller motors than the NEMA 8?
Kristoffer
Group: DynoMotion Message: 6554 From: himykabibble Date: 1/23/2013
Subject: Re: Camera lens control with miniature stepper motors
Not trying to lose Tom business, but you might consider looking at motors, drivers, and controllers for small robots. They're cheap, and very easy to setup and program. There are quite a few sources on-line for parts, with lots of tiny gearmotors, many with encoders, and single-board controllers with integrated drivers for DC motors and small steppers. And, of course, they can be powered by a small battery. KFlop is a wonderful thing, but it just seems like serious overkill for the type of application you're talking about.
Ray L.
> Thanks,
> Kristoffer
Group: DynoMotion Message: 6555 From: chrismd500 Date: 1/23/2013
Ray,
Thanks for your reply. I will look into that. I agree that kflop/kstep is a overkill for the lens motor. The only reason I wanted to use kflop is that my scanner is a 4-axis machine running everything else using kflop/kstep with a modified KMotionCNC software. So it will be easier to use an available channel on kstep instead of getting into new controller and software. But I definitely agree that it's overkill. If I wasn't already using kflop/kstep and I wanted the lens control only, I would probably not use kflop.
Kris
> Regards,
> Ray L.
> > Thanks,
> > Kristoffer
Group: DynoMotion Message: 6556 From: himykabibble Date: 1/23/2013
Kris,
That makes sense. But I'd still look to robot parts for the motors, drivers, etc. Some of them are incredibly tiny. You could also consider using R/C servos. They are trivial to control with any microprocessor just using a single I/O pin. In fact, you can control up to 9 of them with a single I/O.
Ray L.
> Ray,
> Thanks,
> Kris
> > Regards,
> > Ray L.
> > > Thanks,
> > > Kristoffer
Group: DynoMotion Message: 6559 From: bennyattwell Date: 1/23/2013
for something that small why not use just a darlington driver array driven by the kflop.
ive worked for 25 years on "fruit machines- gambling machines" with small steppers to drive the reels. they are always driven with a simple 2803a darlington driver with current limited by a resistor in series.- very reliable!
i use these to boost my output signals to drive air solenoids etc on my machines.
> Ray,
> Thanks,
> Kris
> > Regards,
> > Ray L.
> > > Thanks,
> > > Kristoffer
Group: DynoMotion Message: 6560 From: chrismd500 Date: 1/23/2013
Ray, yes I've been looking for "robot" parts, and it seems to be a lot I can use there, and its cheap too :) Thanks for the idea!
> Kris,
> Regards,
> Ray L.
> > Ray,
> > Thanks,
> > Kris
> > > Regards,
> > > Ray L.
> > > > Thanks,
> > > > Kristoffer
Group: DynoMotion Message: 6561 From: chrismd500 Date: 1/23/2013
That is interesting! I'm not exactly sure how a darlington driver works (I'm a little newbie on this). But if it's easier than putting a motor there I'm all for it. I'll read up a little on the darlington to see if I can understand it better.
Thanks!
> > Ray,
> > Thanks,
> > Kris
> > > Regards,
> > > Ray L.
> > > > Thanks,
> > > > Kristoffer
Group: DynoMotion Message: 6563 From: Shannon Davenport Date: 1/23/2013
I used a small stepper from a printer to focus a large telescope.  I too drove it with darlingtons which were biased with a quad encoder.  I used an Oring for the belt and it slipped at the end of travel.
Thanks!
> > Ray,
> > Thanks,
> > Kris
> > > Regards,
> > > Ray L.
> > > > Thanks,
> > > > Kristoffer
Group: DynoMotion Message: 6564 From: himykabibble Date: 1/23/2013
A Darlington driver would be the electronics to drive a small motor. It would be suitable only for very small motors, and only really practical for unipolar stepper motors. Since you're apparently not electronically inclined, I'd recommend sticking to off-the-shelf motor drivers. For the kind of motor you need, they'll cost you less than you'd spend trying to build something yourself. I've seen them as low as about $6 for small motors.
Ray L.
> Thanks!
> > > Ray,
> > > Thanks,
> > > Kris
> > > > Regards,
> > > > Ray L.
> > > > > Thanks,
> > > > > Kristoffer
Group: DynoMotion Message: 6565 From: chrismd500 Date: 1/23/2013
I'm definitely not very electronically inclined, and it's very hard to hide that, especially here :) My field is aerodynamics, and how I ended up here is a different story. But electronics is fun when it works.
So if I understand you correct, I will need another controller board? How/where do I physically connect that to the kflop and how do i control that via the software / C-code?
When I search for darlington motor driver I just get some IC components and not a complete board. Any idea where I can find some of these boards?
Thanks. I really appreciate the help!
> Regards,
> Ray L.
> > Thanks!
> > > > Ray,
> > > > Thanks,
> > > > Kris
> > > > > Regards,
> > > > > Ray L.
> > > > > > Thanks,
> > > > > > Kristoffer
Group: DynoMotion Message: 6566 From: chrismd500 Date: 1/23/2013
That is exactly what i want to do. Awesome. Thanks.
> > Thanks!
> > reliable!
> > machines.
> > > > Ray,
> > > > Thanks,
> > > > Kris
> > > > > Regards,
> > > > > Ray L.
> > NEMA 8?
> > > > > > Thanks,
> > > > > > Kristoffer
Group: DynoMotion Message: 6577 From: bennyattwell Date: 1/24/2013
just came accross this while "shopping"
http://www.ebay.co.uk/itm/DC-5V-Stepper-Step-Motor-Driver-Test-Module-Board-ULN2003-5-Line-4-Phase-Arduino-/370632015541?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item564b63beb5
might be small enough for what you want?
> > > Thanks!
> > > reliable!
> > > machines.
> > > > > Ray,
> > > > > Thanks,
> > > > > Kris
> > > > > > Regards,
> > > > > > Ray L.
> > > NEMA 8?
> > > > > > > Thanks,
> > > > > > > Kristoffer
Group: DynoMotion Message: 6579 From: chrismd500 Date: 1/24/2013
That's funny, I saw these that yesterday. Seems to be a lot of them for sale on ebay. But since I'm a newbie on this; how/where do I connect it to kflop? And how do I operate it?
Thanks.
> > > > Thanks!
> > > > reliable!
> > > > machines.
> > > > > > Ray,
> > > > > > Thanks,
> > > > > > Kris
> > > > > > > Regards,
> > > > > > > Ray L.
> > > > NEMA 8?
> > > > > > > > Thanks,
> > > > > > > > Kristoffer
Group: DynoMotion Message: 6583 From: Tom Kerekes Date: 1/24/2013
Hi Kris,
It looks like you would wire it to 4 KFLOP IO.  I think the 4 inputs will be:
A+ A- B+ B-
So to full step the motor you would alternate toggling the A and B phases.
0 1  0 1
1 0  0 1
1 0  1 0
0 1  1 0
then repeat
KFLOP's Hardware Step/Dir Generators don't have a mode to drive 4 pins like this.
You would need to do this with a User Program.
To Full Step at 100 Hz
ClearBit(AP);SetBit(AN);ClearBit(BP);SetBit(BM);
Delay_sec(0.01);
ClearBit(AN);SetBit(AP);
Delay_sec(0.01);
ClearBit(BN);SetBit(BP);
Delay_sec(0.01);
Delay_sec(0.01);
ClearBit(BP);SetBit(BN);
Delay_sec(0.01)
Another approach might be to use a KFLOP Axis channel and a Hardware Step/Dir generator (set in Quadrature mode) to generate A B signals then just quickly as you can create the complementary signals with software.  This would probably work well up to about 1000 Steps/second.  It would be a simpler User Program and also allow you to Jog at various speeds easily and would handle acceleration.
The User Program to generate the complementary signals could be:
For(;;)   // loop forever
    WaitNextTimeSlice();
    SetStateBit(AN,1-ReadBit(AP));
    SetStateBit(BN,1-ReadBit(BP));
Or you could spend a few more $ and buy something that accepts Step/Dir :}
Group: DynoMotion Message: 6585 From: chrismd500 Date: 1/24/2013
Thanks Tom. This actually helped me understand a little more how this works. So the PWM signal will alternate the A and B phases you described below, and the PWM frequency (=average voltage) controls the speed? Is the 'on' PWM signal ~equal to the supply voltage, i.e. if I have a 24V power supply, will the PWM be alternating 0V and 24V? If that is the case, then the motor speed should be different for different supply voltages?
I think I will opt for a step/dir motor to avoid complicating this more than necessary...
Thanks again.
Kristoffer
> Hi Kris,
> A+ A- B+ B-
> 0 1  0 1
> 1 0  0 1
> 1 0  1 0
> 0 1  1 0
> then repeat
> ClearBit(AP);SetBit(AN);ClearBit(BP);SetBit(BM);Delay_sec(0.01);
> Delay_sec(0.01);
> Delay_sec(0.01);
> Delay_sec(0.01);
> Delay_sec(0.01)
>     WaitNextTimeSlice();    SetStateBit(AN,1-ReadBit(AP));
> From: chrismd500
> Sent: Thursday, January 24, 2013 5:57 AM
> Subject: [DynoMotion] Re: Camera lens control with miniature stepper motors
> Thanks.
> > > > > Thanks!
> > > > > reliable!
> > > > > machines.
> > > > > > > Ray,
> > > > > > > Thanks,
> > > > > > > Kris
> > > > > > > --- In mailto:DynoMotion%40yahoogroups.com, "himykabibble" wrote:
> > > > > > > > Regards,
> > > > > > > > Ray L.
> > > > > NEMA 8?
> > > > > > > > > Thanks,
> > > > > > > > > Kristoffer
Group: DynoMotion Message: 6588 From: Tom Kerekes Date: 1/24/2013
Hi Kris,
I actually wasn't thinking about PWM'ing anything.  I think if you use +5V supply with the +5V motor there isn't any need.  Just switch a coil on and leave it on 100% until it is time to make another step.  If you wanted high speed you would need to use a higher voltage supply and PWM the IO to keep from burning out the motor when going slow/stopped.
